    Australia
    I downloaded the program and the required .dlls (yes, I made sure they were the right type for my processor) put them all in the same directory, but the program won't recognise ssrc.dll. How can I fix this?
    EDIT: Nevermind. For some reason the .dlls for Athlon processors work on my Pentium 2, and the .dlls for Pentium 2s don't work for me
    Australia
    Anyone?
    Budapest, Hungary
    Where did you download the codecs from?
    See the about section in headac3he
  4. I've got the same problem that Legionpc had.
    I have an Atlhon (non XP) and it don't matters where hell I put the ssrc.dll, neither which version it is, it won't work.
    Belive it or not, I've been using Netscape Winamp to ressample the WAV sound files
    Australia
    I solved the problem though, by using Athlon .dlls instead of the Pentium 2 ones.
