Hi, I was just wondering what program I will need to use to put a "Please insert disk 2" at the end of the movie of disk 1? I think I might know but I would like to verify here, thnxs alot![]()
Results 1 to 10 of 10
Just use any picture editing software (Paintshop Pro, etc) to do up an image 720x576 or 640x480 (PAL or NTSC) and print the words "Insert Disc Two" or whatever onto it. Save the file as a bitmap or jpeg image and then drag this into Nero. That ought to do it.
K what if I want the presentation to have motion effects??
like moving objects? does that change the whole scenario? -
It's easy to make them in almost any video editor. I have used Pinnacle Studio 7 and the WindowsXP Movie Maker 2 beta works ok.
If you want complex movements of graphics not in any transition packaged with the app you'll want to consider a higher priced program like Ulead MovieStudio 6.5 or Adobe Premiere.
Or you can get them off the Internet in a few places (see below)Panasonic DMR-ES45VS, keep those discs a burnin' -
Ok thnxs, one more thing...
And to control the duration? I dont want it to show for 2 seconds and then see that damn LOGO of my dvd player... can it be "looped"? -
If it's a still you can set it to pause or it it's another MPG you can set it to loop. However, that's a little more tricky unless you know XML or use a program (eg. TSCV).
Try VCDeasy - it'll loop the extro & is like TSCV - www.vcdeasy.org
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Insert Image
By von_25 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2008, 12:35 -
Can't insert serial no
By mysts in forum ComputerReplies: 3Last Post: 8th Mar 2008, 20:48
