I am new to this - i wanted to create a SVCD/XVCD quality CD to play on standalone DVD player. I am going to use TMPGEnc to encode, and use Neor to burn.
I would like to encode at a higher bitrate than 1150 that was available on the template that comes with TMPGenc. I have also looked at Sefy's template as well.
I just does not seem to find the option to change the bitrate!!! Help (It seems other varaibles can be changed-but bitrate is greyed-out!)
Thanks in advance
Yes, as you increase the bitrate the picture quaility improves and artifacts disappear. If you use multipass VBR things get even better.
Can you change the video bitrate with Multiavchd?
By jbitakis in forum Authoring (Blu-ray)Replies: 0Last Post: 28th Nov 2011, 01:57 -
mkvmerge Videosize/Bitrate change after merge?
By ck0 in forum EditingReplies: 6Last Post: 8th Sep 2010, 07:57 -
How do I change an .H264 TS video file's bitrate?
By bubbrubb in forum Video ConversionReplies: 1Last Post: 15th Feb 2010, 14:47 -
change audio bitrate in ConvertXtoDVD
By ecc in forum Video ConversionReplies: 9Last Post: 16th Nov 2008, 22:15 -
change video bitrate
By Ogilvy in forum EditingReplies: 2Last Post: 3rd Jul 2008, 14:07
