Hi all,
I’m trying to convert a VBR Divx movie (Black Hawk Down; 23,976), but encountered some problems.
I used VirtualDub to extract the sound (mpeg layer-3) to a WAV file. When opening the file a got the VBR message but as far as I know I can just ignore that. After doing this, I use VirtualDub as my “frame server” for the subtitles.
In Tmpeg I use Toolame for audio layer 2.
I use the movie.vdr.avi file, which the VirtualDub frame server makes, as my Video source and the WAV file as my audio source. First I laod the video source and then the audio source but at that point Tmpeg freezes and doesn’t do anything anymore.
Could this be due to the VBR or is it my processor? Or should I first convert the VBR movie to a CBR movie? It worked just fine with other movies.
Rob![]()
Your movie is probably corrupted so use this guide here and try if it works:http://www.vcdhelp.com/forum/userguides/135552.php
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 16:20 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 06:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 13:01 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 04:31
