Product Using: EZCD CREATOR 5 Platinum 5.3.2 latest update
Below is what I'm trying to accomplish:
01 Start Sequence - An Intro I made
02 MAIN MENU - Has 2 options, Press 1 to Watch Movie, Press NEXT to go to Sub Menu/Scene Select
03 SUB MENU has the chapters of the entire movie, that you can select. Press 2 to go to scene 1, Press 3 to go to scene 2, etc.
NOTE: All Menus are moving.
NOTE: I have broken down the entire movie into chapters already, so that scene selection is in fact possible.
THE PROBLEM:
Whenever I place the VCD into my DVD player Sony DVPNS315 it runs perfectly. HOWEVER, by pressing 1 - which technically is supposed to take you to Watch Movie- it instead takes you to the Start Sequence. As if by pressing 1 you are going to Chapter 1 of the VCD and not a command of pressing 1 takes you to - insert desired place here-in my case Watch Movie
PLEASE HELP ME, ANYTHING HELPS!
It's a portfolio piece of mine and I need help ASAP!
Many Many Thanks!
