Hey guys, I have a couple of questions regarding a movie I encoded. I have a movie in Xvid format. I extracted the audio (AC3) with VirtualDub and HeadAC3he. After I encode the movie and the wav file with TMPGEnc Pro using VBR I get jerkiness in the movie even when there aren’t fast motion scenes both on the converted mpg file as well as when I play it on my DVD player. I followed this guide http://www.vcdhelp.com/forum/viewtopic.php?t=119019 but I still get the same problem. I scanned the movie prior with VirtualDub for bad frames, it didn’t find any problems.
Does anyone have any ideas on how to fix this problem?
MikeWeb
http://mikeweb.atnet.ca -
Have you encoded the xvid with the same framerate in TMPGEnc??
If you have changed it with TMPGENc from say 23.976 to 25fps TMPGEnc
adds frames and therefore you get jerkiness. If you want to convert the framerate this is a great guide:
http://www.vcdhelp.com/forum/userguides/138106.php -
This is what I get when I load it in VirtualDub
MikeWeb
maybe you'd like to read this thread too: http://www.vcdhelp.com/forum/viewtopic.php?t=132640
Jack -
It's the VBR. My DVD player won't play it properly and gives me that stuttering effect no matter what I tried. So now I use a lowered constant bitrate for making files small enough to fit on one CD (if it's a shorter movie in the 1hr30min range) or the normal NTSCfilm template for regular encoding.
Here's the thread discussing the ONE CD methods. I used the CBR version with great success.
http://www.vcdhelp.com/forum/viewtopic.php?t=84759
How to fix MPEG encoded with wrong aspect ratio?
By Talayero in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 10:29 -
Can I fix an incorrectly encoded MPEG4 file?
By wiseant in forum Video ConversionReplies: 10Last Post: 16th Oct 2008, 19:57 -
how to fix broken mpg file?
By ecc in forum Video ConversionReplies: 4Last Post: 6th Oct 2007, 08:56 -
How to fix this strangely encoded video?
By PTRACER in forum Video ConversionReplies: 19Last Post: 25th Sep 2007, 21:51 -
Bad NTSC to PAL converstion - jerkiness. How to fix?
By PTRACER in forum Video ConversionReplies: 34Last Post: 11th Sep 2007, 18:00
