  1. I got ahold of some cdrwin 5 files that end with cdr my problem is I don't wont to burn the stuff to disks I want to extract it to the hard drive. I haven't found any programs to do this. And this really needs to be done bad. the image sizes are to big to put on a cd-r/w so that is outa the question. any help would be, well...helpfull thanks
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    rename them to bin or iso and extract w/ isobuster ..
    cdrwin 5 is not a good program anyway ..
    stick / the REAL cdrwin .. 3.9x
  3. yep I've noticed it's pretty bad. I did a restore point because some people had said it wouldn't uninstall and they had to reformat and start a new system install. I'll try the methode you mentioned and see what happens. I know that vcdgear wouldn't extract the file either.
  4. that did it thanks
