Hello my friends,
I found this post in kwags forum, but I have no idea of how it works.
It actually says that its possible to make a hq 150 min svcd that fits a 80 min cdr.
This is what it says.
xxxxxxxxxxxxxxxxxxxxxxxxxxxx
When trying to get further optimization (increase video quality, reduce
filesize) I´ve tried to encode the movie in interlaced mode (cause the
TV set displays in interlace mode anyway).
So instead of 25 fps non-interlace (progressive) I selected 50 fps
interlaced. This needs to select MP@HL in MPEG2 mode.
Test encodings of 1min samples issued filesize of about 60% for interlaced
compared to non-interlaced (100%). At 448x448 active SVCD
windowsize (in 480x576) I´ve got ~ 5MB/min @ cq 75 in TMPGenc
bringing a total playing time of about 150min at fullSVCD resolution.
The trick is using field based encoding instead of framebased encoding. My S/A player Panasonic RV32 plays this flawlessly (so far).
I still get some block artefacts in scene changes so I´ll try further optimizations (field order, etc)
Maybe someone will check this too and let us know the results of
his S/A player (some players are known to run into trouble @ field based
encodings)
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Does anyone knows what he meant??
If so, how to do this???From wich template did he started?
I´ve posted this over there also, if I have some news, I let u guys know.
THANXS
Results 1 to 12 of 12
well that's crap. i dotn' believe you can fit more tahn 80minutes of decent quality movie on to a 80minute CD-R. I usualy make my movies into 2 CDs, and the quality is real good
Hi there,
Was looking at your post as I was looking for something else. Over ayear ago I stubbled over the same type on thing. I got a full film ( Blade 2 ) on a cd, was very good quality. "352 x 576" It was 970Mb in size. But that was a while ago and can't remember how I did it. But I did use some of the settings that you used. But I did use Avisynth. Have lost all records of it because of PC formats and other stuff. But what I will say is that you need to change your GOP settings and Quantize Matrices to get more compression. Hope it all goes well!
Pussy!-Keep going till you get it right!!! -
That might give you a watchable "XSVCD" but definately not a HQ SVCD if I translate HQ to High Quality. But then again, quality is in the eyes of the beholder...your GOP settings and Quantize Matrices to get more compression
/Mats -
Point was that you could not fit more that 80mins on CD you can! If you want better quality you put it on DVD!
Actually, the point was how to put 150 min high quality SVCD on a CD. Counter point was: You can't.
/Mats -
It is true that you can get quite a lot on a 80min CD. Kwangs SVCD template for TMPG does a supprising good job.
Amongst the refinements he made was the modified glop structure into a very long string IBBPBBP........BBPI.. and on a TV it is better to sacrifice Horizontal resolution rather then vertical resolution, ie 720*256 is inferior to 352*512.
I created some home video using the Kwangs SVCD template (I was lazy and didn't separte the audio) and tested it on 4 DVD players and it worked perfectly despite being non standard -
Just my two cents. Kwag has done alot of good work with XSVCD and XVCD templates. But just keep in mind these are X-type formats meaning they are NON_COMPLIANT. I use an offshoot of his templates for TV episodes and the quality is very good. I stopped using alot of his templates as DVD prices have fallen, but the best way to judge his work is to try it, all you'll lose is a couple of CDs, and some time. But then you can chalk it up to learning 8) .
Hi,
Like mikesbytes and thegig, I have used Kwag's KVCD templates for VCD and SVCD, and I found they're pretty good. I don't know about the 150 min of HQ SVCD in a 80-min CD though. I did stuff 2 Hr+ movie in 1 80-min CD, but I usually used the VCD templates.
Sometimes I used Kwag's Half-D1 templates (352x480) to create my videos and author it on DVDs. The last of such project was the movie "Lagaan", which is a 3hr 40min epic. Kwag's Half-D1 template produce a very good outcome, and it fit well in a 4.7 GB DVD. I tested in 7 different DVD players, and all play it fine.
Cheers, -
In TMPG there is CQ setting's you can get alot of space on the disc but it's blocky.
The advantage in using Kwang's templates is that he has done the gruntwork in finding TPMG settings that maximise the quality that can be produced for a format for a given file size. They are a good reference point for anyone who wants to push the 'envelope' while retaining compatibility with most DVD players.
With a good quality input 120 minutes of good quality xSVCD is easily acheivable on a 80min disk. 150 is pushing the envelope, but it can be done. -
well to put 150 min in a 80min cdr in HQ-(X)SVCD only if the movies hasn´t any action or shrinking the image (big borders top/bottom)
kwag templates + Avisynth (script by Jorel) are excellent i used to do 120 min on a cdr 90min w/quality but as (x)vcd (100% quality)
certainly the HQ in the sentence is to show that w/kwag settings quality is better
and they are
Hauppauge 150: Another Odd Problem
By Tom Saurus in forum Capturing and VCRReplies: 0Last Post: 12th Jun 2010, 12:22 -
Bitrate problem - PVR-150
By m0dts in forum LinuxReplies: 4Last Post: 14th Dec 2009, 14:47 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
samsung dvdr-150
By rjgti in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Mar 2008, 14:42 -
You folks were right, Hauppauge 150..
By The Fred in forum Capturing and VCRReplies: 3Last Post: 8th May 2007, 14:39
