  1. I am creating a NTSC DVD complaint movie (from my home movies)
    I am converting my video in CCE 2.66.
    I am converting my audio in TMPGenc.
    I am multiplexing with TMPGenc.
    I am authoring and burning with moviefactory 2.
    The only way that moviefactory 2 does not re-encode is if I set the audio in TMPGenc to MPEG 1, Layer 2, 48000, stereo, bitrate 256.
    If I change it to 384 (the standard bitrate), it re-encodes. When I use TMPGenc to do it all, it does not re-encode even when using audio bitrate of 384.
    My question: Is it bad (in terms of audio quality) to reduce the bitrate to 256 from 384. Is there a noticeable difference? Thanks.
  2. I can hear the differance, with my very good sound system. Most people cant. Try it out for yourself. If your sound system sucks, then it dosn't make a difference.
  3. Thanks for your reply. Do you have any idea why moviefactory 2 would re-encode one and not the other? Thanks.
    Apr 2002
    Oskeeweewee Ontario
    Perhaps using a bitrate of 256 is throwing things off. It seems that most people use either 224 or 384.
  5. when I check the audio on Store bought Stamped DVD's the audio reads like this
    2 channel - 192
    4.0 channel - 224
    4.1 or 5.1 - 384
    These seems to be the standards within the DVD community
