I remember reading on this forum about this problem, but couldnīt found it any longer.
My capture card is a MSI GF4 TI4200 VTD8x.
The problem that I have is that on very bright pictures, the capture seems to loose focus, and some color end up disapearing.
I have some images captures that have a very birght background, mostly Desert sand, and most of minor changes of the picture simple disapear (It appears do blend white/yellow and other bright colors togheter.)
On darker images this problem does not occurs.
Has anyone have this problem? and if so, theres is any solution for it?
Thank you.
Results 1 to 1 of 1
"You must be the change you wish to see in the world" - Gandhi
Msi/asus/dell editing laptop?
By amigo-productions in forum ComputerReplies: 11Last Post: 6th Dec 2011, 01:45 -
msi motherboard replacement
By mixxerr in forum ComputerReplies: 10Last Post: 21st Aug 2008, 00:09 -
recommendations for motherboard ASUS or MSI?, dual amd 64 ?
By poolenglish in forum ComputerReplies: 3Last Post: 8th Jun 2007, 16:05
