  1. I created a .mpg file (VCD-PAL format) using Adaptec FireConnect 4300. I am trying to put my files on a CD using Nero. For some reason it doesn't recognize my Toshiba CD-RW drive and Nero always associates my files with the Image writer and I am prompted to save my files of type .nrg. All I am doing in Nero is , select my files and say Write-CD. In Nero under Recorder (Choose Recorder) Menu I am not able to select my computer as the recorder. What am I doing wrong? I have XP Home. Is there any workaround for this?
  2. Sounds like Nero doesn't support your writer. If your writer didn't come with software try EasyCD Pro. The majority of CD burners falls with one of these two software.
    They are both easy to use.
  3. Petco,
    Thanks. As you said Nero might not be supporting my writer. Am going to go with VCDEASY. Thanks again.
