hi, im kinda new to all of this and didn't know what to do with this kind of file. I downloaded a couple of movies with this extension thinking this was a cd image so i could just burn it to a cd-r using clonecd.
But that doesnt work.
Can someone help me out with this?
Tnx
With a Bin extension? you need to burn bin files with either Nero or CDRwin or VCDEasy.
however i don't think you are going to be able to burn those files anyway because they don't have a cue file with them. -
you could either make your own cue file if you know how or you can extract the mpeg movie file from the bin with a program called cdmage, its in the tools section
If you feel that you want to write an iso file instead of a .bin for whatever reason..
Use bin2iso (http://users.andara.com/~doiron/bin2iso/) to convert your cd, then either write to a cd-rw to make sure it works or use winiso to look inside the file before writing to the cd-r. I've used bin2iso in the past on data discs, but never on a vcd so you may want to try the winiso or cd-rw thing.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 02:02 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 08:16 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
