Hello, its my first time making an SVCD. VCDs on my DVD do work however when i encoded an MPEG-1 file with TMPGENC to an MPEG2 file then i burned to a CD-r with Nero 5.10 with the SVCD feature and then i played it and nothing was on the screen although the timer was running and there was two tracks???
Also in Tmpgenc should the file be interlace or not? i dont get that feature and should the size be 480.480 or 480.576
thx
I had issues using Nero to make SVCDs where they would not work yet the test SVCD you can download from this site did. I switched to VCDEasy and SCVDs now work.
Try VCDEasy.
480x480 = NTSC (USA)
480x576 = PAL (Europe)
Depends on where in the world you live. -
Diamondom:
Looking at the users reports and comments in the DVD players section for your particular player:
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=701&Search=Search&#comments
it looks like you need to do the VCD header trick to be able to use the SVCD specification. Just use the search function in the forums and you will find many postings on how to do it.
SVCDs are supposed to be interlaced. -
Thanx, the people on this board are so fast to reply, its amazing...
OK . i have look in tmpgenc to see how i encoded it; here it is; correct me if im wrong
VIDEO
video stream type : MPEG2
Aspect ratio: 4:3 but can i put it to 16:9?
frame rate 29.97
Rate control mode: CBR
Bitrate 2250 (is that too high?)
UBV: 40
Video format: NTSC
ENCODE mode: non-interlaced (so it should be interlaced?)
YUV format; 4:2:0
DC comput: 8 bits
ADVANCED (video settings)
Video source setting:
Video source type: non-interlaced(progressive)
Field order: top field first
Source aspect:1:1 (VGA)
Video arrange method:Full screen
im using tmpegplus 5.6 or 5.7
plus nero 5.10
thanx for helping me
Problems with JVC HR S6900U VCR.
By Video converter in forum Newbie / General discussionsReplies: 0Last Post: 9th Nov 2010, 13:31 -
my current camera (jvc gr dv500) is messed up. making noises n weird lines
By bojadada in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 10:09 -
Pinnacle 9 - JVC cam problems
By Maarten in forum Capturing and VCRReplies: 3Last Post: 19th Jan 2009, 16:38 -
JVC DR MV-7 reading problems after hacking
By PTCAL in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Feb 2008, 03:47 -
JVC XV-S40BK Factory Reset
By mb300e in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Aug 2007, 18:58
