    Jan 2003
    Cheyenne, Wy
    is it only possible to cut an .avi file can you make it into mpeg then cut it?
    Jan 2003
    Best Coast, Canada
    I'd even recommend you to convert it to MPG file first and then to cut it (using TPMGenc). That should prevent from some audio probs.
    Jan 2003
    Cheyenne, Wy
    ok thats what i was wondering cause ive been having problems with the audio video snychronization being good on one half of an .avi the the other half is messed up. or its good most of the way through the file till it gets to like the end then it messes up
    ok thanks for the info
