Also called UDF bridge, UDF/ISO is a hybrid filesystem utilizing UDF and ISO 9660. Developed because UDF wasn't supported by Windows until Microsoft shipped Windows 98, DVD providers were forced to use an interim format. Windows 95 OSR2 supports UDF Bridge, but earlier versions do not. As a result, to be compatible with Windows 95 versions previous to OSR2, DVD vendors had to provide UDF Bridge support along with their hardware.
DVD-ROM discs use the UDF Bridge format. (Note: Windows 95 was not designed to read UDF but can read ISO 9660). The UDF Bridge specification does not explicitly include the Joliet extensions for ISO 9660, which are needed for long filenames. Windows 98 and later MS operating systems read UDF so these systems have no problem with either UDF or long filenames. Burnworld
Results 1 to 1 of 1
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 09:44 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 20:37 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 13:10
