I have encoded my avi file in TMPGEnc as a DVD MPEG 2. However i now have 2 files, the PCM Audio file and the M2V video file. How do i put these together so i can burn the finished movie to DVD? I Have tried using simple multiplex in TMPGEnc but i get an illegal MPEG stream error when i try to use the audio file. I also ripped the audio using VirrtualDub and tried to use that but i got the same error. I have searched the site and cannot find a tutorial for when you get 2 files.
Please help![]()
If you encoded with TMPGenc you should have an mp2 audio file as well as an m2v video file. You can mux these together using tmpgenc
I'm new to this also and have only used Sonic DVDit for authoring, but I think most authoring programs will take these two files and mux them together when creating your files for DVD.
i have got the M2V but my audio file is a wav. When i try to use simple multiplex with the audio wav file i get the message "multiplexing liniar pcm stream to stream is not supported"
i am pretty sure i encoded it right...just to double check this is what i did with TMPGEnc.
started TMPGEnc
chose DVD NTSC 16:9, & CBR Linear PCM audio
selected the avi file as source video and audio; non interlance, 1:1 VGA and video mode
changed the estimated file size to 4gb to fit onto a dvdr
saved output (it was called filename [m2v+wav])
Then i started encoding
I was left with the 2 files i said...the M2V and the WAV. -
You got what you selected.
PCM means WAV audio, no compression. Change that option.chose DVD NTSC 16:9, & CBR Linear PCM audioTo Be, Or, Not To Be, That, Is The Gazorgan Plan -
ok thank you
So should i choose:
VBR MPEG-1 Layer II audio (MP2)
or
CBR MPEG-1 Layer II audio (MP2)??
Thanx in advance, i am guessing after i have corrected this i will be ok
Have expirence with AVI, never encoded in MP4 before
By Cyber Akuma in forum Newbie / General discussionsReplies: 8Last Post: 11th Jul 2009, 07:33 -
I encoded AVI to DVD but can't burn
By simonuribe in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2009, 16:32 -
encoded .avi to dvd errors?
By mrjust in forum Newbie / General discussionsReplies: 2Last Post: 4th Apr 2009, 22:37 -
what would you recommend to burn encoded .avi's?
By just in forum Newbie / General discussionsReplies: 3Last Post: 30th Oct 2008, 01:05 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 19:55
