I'm using ulead dvd workshop and it is excellent. i have run into one problem though. When putting mpeg-dvd movies on a dvd the movies plays fine, but my menu-buttons is a problem, when burning in NTSC-format everything is fine but in PAL-format the button that links to the movie doesn't get "enlighted" when you choose it. It works in preview but not when playing on my standalone (Thomson DTH 5200). The linking works though. anybody?
raufman
If I remember correctly you can adjust or choose a different color. Pick a darker color or increase the intensity. There is a settings option you can play with.
Simular problems over here......no "enlighting" of hotspots
Keywords:
Ulead, DVD Workshop, Menu Function, SlideShow, Bug, Error, miniDVD
Standalone Player:
Lenco DVD 12, Philips 640
OS: Windows 2000
When playing a DVD Workshop (1.0 or 1.2 or 1.3) created miniDVD on a standalone DVD player, menu’s and menu buttons do not respond correctly. When going to a next or previous menu the output screen will freeze. Only when using the standalone DVD player setup functions the actual screen will return.
(synchronization or color pallet problems ?)
When playing a (same content same senario) DVD PictureShow (1.0) created miniDVD on a standalone DVD player everything will function smoothly as expected.
What is wrong ?
Why can DVD Workshop not be used (such as DVD Pictureshow) to created Multiple Slideshows with stills (or films DVD Workshop only) to created miniDVD’s?
Sander
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 04:26
