Does anyone know of any programs i can use to convert divx 2 svcd at 23 fps and not 23.98 fps ?
When i convert i'm getting a slight stutter on the picture because the divx films i have downloaded are 23 fps and all the programs i have tryed will only convert them to 23.98 fps (closest to 23fps) which is causing the problem, can anyone help please
Ok whore the step to making a good conversion of a divx dvd rip to an mpeg-2 svcd format isOriginally Posted by fitz15
1) open up divfix and put strip index and rebuild index ok and that’s it.
2) Now open up tmpeg and close the wizard. Then where it says audio source put browse and put the movie there. Then you to go file and put out put to file wave.
3) Now once you have the audio its gonna be like 900 mb
4) Now open up virtual-Dub and drag the regular movie in there. Then put direct stream copy and in audio it says wave audio. Click on it and you enter the wave audio that you made with tmpeg. Then you put file save as then you name it.
5) Once you do that you will have the movie combined with the wave audio. The size should be like 1.5 gb or something. Then when you have the full thing you can split it with virtual dub or tmpeg. But I would do it with virtual dub cause I haven’t done it with tmpeg and it might come out wrong in tmpeg.
6) Ok now that the files are split with virtual dub you delete the whole one, the wave audio and if you want to the divx rip but if I were you I would burn that shit first.
7) Now that you have the split files make them to svcd with tmpeg and that’s it.
Ok this is just a brief guide not anything fancy but still and if your familiar with Tmpegenc, Virtual Dub, and Divfix then everything will be alright.Cecilio -
no problem i just hope it helped at least a little.Originally Posted by fitz15Cecilio
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
