I just dl sing for a moment file m2v, how i play dis?
Your soft DVD player should do it.
/Mats -
/Mats -
The file you downloaded is an MPEG2 file. If you don't want to buy a software DVD player like PowerDVD or WinDVD, then download an MPEG2 codec, there are links to some under the Tools section of this website, just look under codecs. You should then be able to open the file with any player you like.
Prospero
Help with m2v files
By Mikhel in forum Video ConversionReplies: 0Last Post: 19th Feb 2012, 06:22 -
Player that can play back m2v and ac3 files in sync
By cheerful in forum Software PlayingReplies: 2Last Post: 9th Sep 2009, 20:48 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 17:57 -
edit m2v files?
By SUPERIOR in forum EditingReplies: 2Last Post: 16th May 2008, 02:42 -
Demuxing Smartripped VOB with VobEdit06... M2V won't play in VLC?
By Iceblade in forum Video ConversionReplies: 12Last Post: 15th Oct 2007, 22:30
