i download the software and use it for 2min (enough for me to see quality)
the quality was good! how ever i found some difrent betwen dvd2one and cce....but for me its the same.
one question i have:
if dvd2one does not rip the menu, how can i switch between Audio (DTS,5.1-if i rip them both) ? or how can i switch between subtitles, again if i rip 2 sub's?
anyone have answer?
i did not bought it yet b cuz of this reason...
Look on your DVD remote. It usually has a button that sais audio on it. By pressing it, it will go through the different available audios. It will also tell you what they are as you go through them. The same goes for sub titles. Your remote should have a sub title button, keep pressing it till you are on the one you want. Remote restrictions are turned off in the ifo file. Unlike some commercial dvds where they force you to select what audio or subs in the menu. I prefer to be able to switch. Gives me the ability to compare the audio stream with the push of a button. I usually prefer DTS myself but I always rip DD and DTS with english subs.
oh...stupid me!! yes avcorse...
one more question:
if i want to Author after dvd2one has finished, there is a way to do a menu that i can choose between the sub's and audio tracks?
when you buy it online, what is the time you wait until you get this 100kb
software? -
I had it in about 1-2 minutes. How ever fast your email is. I am sure you could implement it in a menu setup like spruce. But why waist the space for a menu, when you can leave it for the video quality?
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
LG CH08LS10 just a quick question or two ?
By MidnightMike in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Nov 2010, 04:51 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 07:21 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03
