Hi,
I was wandering if theres some sort of patch or add on to allow tmpgenc to open dv avi files. I caqpture with adobe premiere, but if i save it as a normal windows avi file there is quite a quality difference betwwen that and the dv avi. Will it make a difference if I go straight from dv to mpeg?
Thanks.
If you are capturing type 2 DV files, you need to install a DV codec. For example the Panasonic DV codec in the tools section.
If you are using type 1 DV files, you need to change certain settings in TMPGEnc. I manage to get TMPGenc to recognize type 1 files. I believe that it is by setting the priority setting in TMPGEnc for directshow at a higher setting, for example, +4, you increase the chances of compatibility with type 1 DV files. The exact instructions to do this are the following:
In TMPGEnc, select:
Option >Environmental setting > VFAPI plug-in > Right click the "DirectShow Multi Media File Reader" > select higher priority, do this several times until its at the top with a value of 4. -
just a note on the fact that there is no such thing as "normal windows avi file"
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35
