I have a movie which consists of 4 CD's. Each CD contains a large MPEG. Each MPEG plays fine, beginning to end, with the sound nicely in sync.
When I use tmpgenc to join cd1 and cd2, the resulting MPEG shows a sound sync problem in the second half. It's like there's 5 seconds of pictures missing at the join, while the sound runs normally, so at the join, the picture jumps 5 seconds ahead of the sound.
Has anyone else ever encountered this, and how do you fix it?
I have looked for other joining software, but M2-Edit is too expensive and none of the shareware/demo packages will run a file this size.
Thanks for any help.
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner -
Maybe you should load each mpeg into TMPGEnc Merge&Cut and cut a little off the end of each, if they dont finish at a GOP, then the join wont be very good.
KingJohns Guide Merging Mpeg1
KingJohns Guide Splitting Mpeg1
Thanks KingJohn.
Now, from reading your guide: should I first TRY to go through a manual edit of CD1 and CD2, thus manually 'tagging' first and last frame, and see whether it joins both streams in sync, or should I start chopping frames off rightaway?
patrickMy system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Here's what I tried, that DID work.
I demuxed each of the 4 CD's. I joined all 4 video files together. I joined all 4 audio files together. I remuxed the video and the sound.
I now have a working movie!
It does appear a tiny bit jerky every now and then (when the camera is panning, the movement isn't always as smooth as it could be), so I'll play around with a few different encoding options.
But other than that, it finally works!My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Originally Posted by pvanosta
Oh you can put all that signature stuff in your profile -
Thanks Kingjohn.
If you see my last post, you will see that I tried something else which DID work, more or less.
Tagging the start and end of CD1 and CD2 did not resolve the issue.
Demuxing all 4 CD's, then joining the 4 video streams together and (separately) the 4 audio streams together, followed by a remux of the audio and video, produced a working file, with in-sync sound.
the picture is a little choppier than the original though. Considering the originals were 4 mpeg2 files and the final resilt is a single mpeg2 file, should they not be the same quality?My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Sony 8x DVD burner
Edit .mkv file (split/join) - nothing works "properly"!!!
By The.King in forum EditingReplies: 19Last Post: 11th May 2013, 06:23 -
How do i get an iso to burn properly?
By EdJr in forum Newbie / General discussionsReplies: 36Last Post: 23rd Jan 2012, 16:37 -
how do i properly convert FLV's ?
By daflip in forum Video ConversionReplies: 5Last Post: 1st Sep 2009, 14:57 -
Why my PC cannot play HD video properly?
By kouras in forum DVB / IPTVReplies: 5Last Post: 19th Dec 2008, 08:25 -
mkv's not working properly
By runLoganrun in forum Blu-ray RippingReplies: 2Last Post: 7th Dec 2008, 13:13
