When converting DivX to *.mpg (VCD) with VirtualDUB frameserving to TMPGEnc, what are the video filters to enable, which can produce the best quality output?
I'm trying to encode with filter SHARPEN and BOX BLUR, but still I can't produce a VCD without boxes in the image. How can I get an VCD image the most look like an DVD image?
Nuno.![]()
I believe you cannot totally remove the blocks/artifacts. You can just reduce it. You can also try VCD of high bitrate(non-compliant).
Personally, I find the gamma filter of around 60 can reduce the VCD artifacts although it won't eliminate it completely. This has a long technical story why the filter can help reduce blocks. However, some people still cannot present the theory I presented. Anyway, gamma correction won't brighten the overall image but it will just brighten the darker area more.
Have you ever considered XVCD? -
Originally Posted by nunesnuno
Consider XVCD as suggested (which will make much better use of low bitrates) or SVCD.
Achieve the best possible audio quality.
By Robertiebert in forum Video ConversionReplies: 8Last Post: 23rd May 2011, 09:35 -
How do i achieve this effect in FCP 5 ?
By d.ennion in forum EditingReplies: 2Last Post: 24th Jul 2010, 21:13 -
how to achieve max quality in fairuse wizard, x264 settings
By llmercll in forum Video ConversionReplies: 21Last Post: 17th Jan 2009, 08:17 -
How can one achieve MAXIMUM PSP video quality?
By The.Yield in forum Portable VideoReplies: 1Last Post: 14th Sep 2007, 00:01 -
Best image quality as possible for AVI videos...FFdshow filter.Any ideas???
By fgtan in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Jun 2007, 14:17
