I can't help but throw in this first joke.
"Your initial problem is you have a MAC." :P (feels good to let that out)
Honestly though, your ram doesn't sound bad. I mean the minimum requirements for most of what you're talking about is 64MB RAM. A G3 SHOULD have the power to process the task as well. You may want to check the media you're using and also check your process of how you're doing the burn. I had a heck of a time with a software from 321 studios once, but found out I HAD TO place all saved movies into a specificly named folder or I would always get errors.
Again, it sounds like your PC is good enough to handle it, but there may be something you're missing or not catching that's causing all the errors to happen. Try reading up on the software you have. Make sure you shut everything else running down. My "heavy duty" PC has a 3.06GHz processor and 1G PC3200 RAM with a nice new SONY DL burner (I caved in). I got an error on my first disc because my antivirus program did an autoscan during a burn. I know some people who surf the net and do all sorts of different tasks while they are burning, but as a precaution, I suggest just let the burn happen on it's own by shutting down all other programs.
If you're more technically advanced, You may also want to consider flashing your optical drive if there is a firmware update.
Hope these give you some ideas to ponder.
Results 61 to 61 of 61
Non-experimental thread on best known VHS > BD / DVD methods
By _yo_wasup_ in forum Newbie / General discussionsReplies: 14Last Post: 17th Feb 2010, 16:28 -
VHS to DVD 4 methods?
By sonomablue in forum Capturing and VCRReplies: 73Last Post: 4th Sep 2008, 22:08 -
Help with converting BBC HD Stream to DVD (Normal methods won't work)
By Killer3737 in forum DVB / IPTVReplies: 3Last Post: 30th Jul 2007, 10:23 -
Are there any methods to get a Ford oem Navigation unit to play dvd video?
By marc32 in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 23:11 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
![Computer details: Windows Server 2012 R2
(2x) 2.93 GHz Hex-Core Intel Xeon X5670
Toshiba OCZ RD400 NVMe PCI-Express 1TB card
(2x) onboard Crucial MX200 512GB SSD
60TB+ NAS storage [mixed amongst Synology 1515+ & 1815+]
144GB Registered DDR3
Plex Media Server Comp](/images/buttons/computer.gif)
