I need to chop like 50 - 70MB Eps to like 15 - 25mb each but i use AVI2CHOP and it screws it up. when i press chop it ends with like a million parts to it and still the parts don't work. Is there a easy way out there to chop 25 mb or 15? any free good prgrams
I am trying to chop by converting the avi to mpg then chopping with tmpgenc but does that make them larger?
I tried using avichop too but i was doing it to delete some freezing frames but to no avail.to answer your question, i think they will be the same mb becuse you're just cutting them and encode them again. encode them and cut them in half using tmpegenc. that's what i did and it worked.
Whats wrong with using Vdub to do this ?
Use keyframes if you do, dont just cut anywhere, jump to the nearest keyframe.
having trouble getting avi to work
By Onceler2 in forum DVD RippingReplies: 5Last Post: 7th Aug 2009, 23:02 -
Trouble with AVI files
By Warhammer in forum Blu-ray RippingReplies: 3Last Post: 24th Sep 2008, 14:25 -
AVI trouble
By AirborneRanger in forum Newbie / General discussionsReplies: 4Last Post: 19th Aug 2008, 00:02 -
Movies in AVI - Trouble
By Jomapil in forum Newbie / General discussionsReplies: 5Last Post: 4th Apr 2008, 22:27 -
Trouble with AVI in ConvertX
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2008, 11:07
