  1. I can rip dvd to vcd fine but I have a problem ripping to SVCD.
    I don't get any chapter jumping and the audio sync goes after about 16 minutes into any disc. Also if I search forward or back for any amount of time the sync goes. Can anyone help me with this. It's probably something stupid but I'm a newbie at this.
    Cheers in advance
    Nikhm
  2. Come on. Someone has got to be able to help me???????
    PLEASE!!!!!!!!!!!!!!!!!!!!
  3. 1)select "Audio/Video synch."
    2)in "iDCT" and "Resize",select the correct settings for your CPU(SSE/3D Now)
    3)play 10 sec. of the movie(to unlock the drive)before encoding
    Some people have reported that ver.2.0 has a synch. bug and recommend using ver.1.7(search www.google.com)
  4. Banned
    Jun 2001
    UK
    Yes DvdX can give this problem, V1.7 is more sutable.
    KingJohns Easy, Quick DVD ripping guide *****
  5. Cheers every1
    I will give it a go and maybe go and get Ver 1.7
    If I have anymore Probs then I know where to go.
    Once again CHEERS
    Nikhm
