Using NERO 5.5.10------
Ok, this is where i complain aobut nero and you people tell me to use another program. I DONT WANT TO USE ANTOHER PROGRAM, ahh that feels better...
DVD-Video-----supposed to be in UDF 1.50 format right? well i burn a DVD+r and it DOESNT work on my standalone Apex AD1500 but it DOES work on my PS2...
DVD-ROM(UDF)------I put the setting for UDF to 1.02 (using DEDUCTION to conclude that my standalone is 1.02 compatible and not 1.50) I burn and i have success on my APEX, but not on my PS2.
So far we have:
DVD-Video=APEX-/PS2+ (1.50)
DVD-ROM(UDF)=APEX+/PS2- (1.02)
Heres the doozy------
DVD-ROM(UDF) set to UDF 1.50-------THis method works on my APEX but NOT on my PS2------
What is going on------why is the 1.50 now working on my APEX?! im sick of trial and error----I WANT ANSWERS!![]()
Use the latest Nero and try DVD-Video and use "X-Box compatibility".
This might work for you.
Pat. -
First Nero does suck and you should use a different program. There are several others that will actually work and are free. I recommend using IFOEdit or IMG Tools to make a ISO image file of your VIDEO_TS folder then burning with DVD Decrypter (all freeware).
With that said, most DVD players will play UDF 1.02. However, there's a bug in the newest Nero that will not burn 1.02 correctly, try finding 5.9.9.17 -
I agree, Nero does suck!! Use another program! I was using Nero, and some DVD's would work and some wouldn't. I was blaming the media because it was cheap. The problem ended up being Nero. I know use Prassi Primo and have been very happy.
Stop being stubborn and convert to the dark side!! -
You need to read this to know the whole (well, still going & going &...) story about Nero... http://www.vcdhelp.com/forum/viewtopic.php?t=127624
Heres the NEW NEWS--------i decided to downgrade my FIRMWARE and downgrade my NERO to the original BUNDLED package. SUCCESS! I dont know what happened, i dont know if downgrading my firmware helped or did nothing at all due to the downgrade of my nero! I DONT CARE----my stuff works on my standalone and PS2, and that is all that matters...ahhhhh...
Record files over 4 Gb in UDF?
By Artas1984 in forum MediaReplies: 2Last Post: 8th Dec 2011, 14:53 -
UDF Video
By Axissally in forum Video ConversionReplies: 11Last Post: 22nd Feb 2011, 14:47 -
UDF 2.5 driver for XP 64bit
By INFRATOM in forum Blu-ray RippingReplies: 2Last Post: 20th Mar 2010, 12:27 -
Burning with UDF
By gooberguy in forum Authoring (Blu-ray)Replies: 9Last Post: 18th Jul 2009, 18:01 -
converting udf to ntsc
By crazyn8 in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 17:07
