  1. i'm pretty new to this and was wondering how to tag my files with a logo and such. any info will be thankful..
    Djinn
  2. Check this page
    http://www.vcdhelp.com/faq.htm#repairmpg
    They mention about adding logo in your film. I've never try it. Good luck
  3. http://sauron.mordor.net/dgraft/logo.html
    1) Download this plugin, install into Virtual Dub's 'plugins' folder.
    2) Create a logo [A good canvas size to create an unobtrusive logo in is about: Width 116 pixels and Height 70 pixels]. I usually create a regular sized logo and then scale the picutre down, cut out unecessary background and then choose a solid color background like blue or red; the filter will make sure that the solid background won't show in the video. I think the filter will only work with bitmap files, not sure you'll have to play around with it and see if it lets you load other file types i.e. jpg, but I'm pretty sure it doesn't.
    3) Open up your video file and then......
    Video > Filters > Click 'Add' and then choose Logo 3 beta 4....etc
    4) Load your bitmap logo into the filter. Play around with the filter's settings [position, duration, etc....] to get used to it > there is a Preview in the filter's menu screen that will let you see exactly how your logo will look on your video.
    5) After finding the right setting's for your logo, frameserve the Video file [make sure 'Full Processing Mode' is black balled/checked] to your favorite MPEG encoder and then encode.
    -good luck
    <font size=-1>[ This Message was edited by: deadpac on 2001-07-06 12:04:22 ]</font>
  4. Member Chopper Face's Avatar
    Jun 2001
    Ottawa, Ontario, Canada
    Ooooh... looks fun. I think I can add some sweet stuff to my movies with this. Thanks for the link.
