Results 1 to 11 of 11
  1. does virtual dub support MOV files? I'm trying to rip the audio from a MOV file to use in TMPGE. Does anyone know if it does support these kind of files or if i need a codec?
    thanks
    _BSR
  2. With the .mov mod to TMPGEnc you can load the .mov right in. and no, vdub doesn't support them.
  3. but when i load the mov into tmpge, i get no sound. any ideas?
    Jan 2003
    Canada
    are you doing layer I or II audio?
  5. it just gives me the option of PCM audio. AM i doing something wrong? When I go to mpeg settings, it says layer II, but it wont let me chnage it (grayed out).
    -BSR
    Jan 2003
    Canada
    make sure that the stream type is set to "system [audio+video]"
  7. it is. I cant think of what I'm doing wrong. It used to work fine, but now nothing. What version are you useing?
    Jan 2003
    Canada
    I'm using 2.53.35.130 TMPGEnc Plus.
  9. Banned
    Dec 2002
    Somewhere I belong
    Try install the quivktime plugin for TMPGenc,install here:
    http://www.divx.net.nz/software/video.htm
  10. I had trouble with the sound with some MOV files with the TMPGenc plugin, I found that reintalling quicktime and selecting to install the "Authoring Component" fixed the problem. Hope this helps.
  11. Член BJ_M's Avatar
    Jul 2002
    Canada
    v-dub can suport MOV files ... load MOV file into vfapiconv and then load fake avi into v-dub
