Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps) - the width is off on my TV screen
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps) - the height is off on my TV screen
whats wrong? my TV is PAL version... but it seems both of them dont work,, how I actually find the right fitting size?
thanks
dont worry about it....it is just the way it is....when i make ntsc vcd's from dvd's i have got from overseas they have little black lines at the top and bottom...nothing to worry about....maybe when you convert it you are not streaching the source to the full area of the vcd....this is easy to fix in tmpg....as you tv should crop off most of the black lines....but if the source is small in the resolution dont streach it to fit the frame of the vcd
well its really annoying because I want to see the whole thing
will I be able to use 320x240?
Parameter is incorrect
By xstoanurag in forum ComputerReplies: 2Last Post: 16th Jun 2011, 20:43 -
Parameter Incorrect?
By The Monkees in forum ComputerReplies: 3Last Post: 18th Mar 2010, 17:41 -
Incorrect Framerate?
By quicksandcupcake in forum ffmpegX general discussionReplies: 1Last Post: 21st Jan 2010, 16:52 -
just like to change screensize of a movie
By Cazz in forum Video ConversionReplies: 19Last Post: 23rd May 2009, 02:18 -
screensize rendering sony vegas
By stompinne in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2008, 17:55
