    Aug 2002
    london
    on my cd's i use a stomper and press-it labels
    so will we be able to get a suitable glue and dvd-r's that are able to join up by hand with a plastic device and still work in a stand alone player
    im sure it must be able to do it glue can be a spray like spray-mount
    or is there a reasion that it can only be done with pressed cd's
    sorry i only have questions no awnsers
  2. LOL... had to edit the post. Thought you were talking about gluing 2 DVD's together.. hehe...
    Dont know a thing about labels. Do the ones for CD's not work on DVD's? Good to know if that's true... I'd have stuck a label right on it!!!
  3. It can make the DVD-Rs skip
  4. why don't you buy the double sided dvd-r's instead of trying to glue 2 disc together cheaper and more reliable than having 2 disc glue to one..
    just my .02 cents
    i think this guy is talking about labeling. god i hope so...
    your dvd player will die if you do that...
  6. My nephew put 2 DVD's in their player and it would not open or play. What a goofy kid. He learned a lesson that day.
    I had to take the disk unit cover off to get the 2 DVD's out. I know this is a little off-topic but reading this thread might give someone a crazy idea.
