here's my problem.
i converted a movie in .AVI format to .SVCD format using TMPGEnc and
came out really good, sound and picture quality both.
But when i cut it using TMPGEnc to fit it on 2 cd's the last 40- 50 seconds
of the movie the sound goes out.
I have try everything i can think of, but nothing seems to fix this problem
PLEASE!!!!!! help!!!!!!!
thanks guys
please use meaningful subjects - kitty
Alternatively cut the avi in virtualdub before encoding, then encode the 2 individual parts of the avi file.
Use bbMPEG. Its freeware. Get it here:
http://www.divx-digest.com/software/avi2mpg2.html
Follow the guide here: http://www.vcdhelp.com/bbmpegedit.htm
Looks difficult, but its not. It works too.
wway -
D_saul
it's very simple. when you split it use SVCD MPEG2 (VBR) instead of MPEG2 (VBR) that'll fix your problem. i have that problem for a long time myself
AVI Cut
By JP in forum EditingReplies: 4Last Post: 6th Mar 2012, 20:12 -
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 10:35 -
mp3direct cut
By RustyBob in forum AudioReplies: 11Last Post: 2nd Jun 2010, 21:50 -
how to cut....
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2008, 03:28 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05
