I'm on my pioneer run to rip a DVD to SVCD. I read the DVD to VCD guide and downloaded Smartripper. The problem is I cant open the file. Everytime I try, the windows error message comes out. Anyone know why and how to fix this problem? I'm using Windows XP Pro with SP1 installed.
Thanks in advance.
Try DVD Decrypter,Smartripper has not been updated in a long time and may not,I said may not,run under XP.
what error???some files locked?
use powerdvd or another player and play the movie for a minute.
smartripper does work under winxp. -
For some reason I got it running, but I find the DVD-Decrypter works better. With Smart Ripper, it works 2 out of 6 tries. Otherwise it hangs or take a really long time to read the files.
Thanks anyway to the both of you for your suggestions and advices.
BD Rebiulder Pretty Smart
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 27th Jan 2010, 16:07 -
Get Smart backup
By Shermanbay in forum DVD RippingReplies: 26Last Post: 11th Nov 2008, 23:54 -
GET SMART no copy
By shoesss in forum DVD RippingReplies: 3Last Post: 7th Nov 2008, 09:48 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
