The block is a matrix of 8x8 elements. They can be 8x8 adjacent luminance or chrominance samples, or the corresponding DCT coefficients.
At the block layer is performed the Discrete Cosine Transform.
Video decoding process at the block layer
Variable length decoding.
The bitstream codewords of the block are decoded to form a vector of quantised DCT coefficient.
Inverse scan.
The vector elements are put into a two-dimensional array, which is the block, following one of two possible patterns. The pattern is defined by the flag alternate_scan which is set at the picture layer. The scanning purpose is to optimize the entropy coding.
Inverse quantisation.
DCT coefficients are converted to their original range of values. See also dct quantisation.
Inverse DCT.
Eventually the IDCT is performed. Now the block elements represent either the image sample (Intra block) or the prediction-error (Non-Intra block).
Results 1 to 1 of 1
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 15:51 -
To block sites
By Jomapil in forum ComputerReplies: 13Last Post: 24th Apr 2012, 19:12 -
DV pixel block help
By cg_society in forum EditingReplies: 3Last Post: 26th Oct 2011, 09:42 -
Digital block out
By homie241 in forum RestorationReplies: 9Last Post: 21st Apr 2011, 06:40 -
Block a file
By Jomapil in forum ComputerReplies: 2Last Post: 11th Nov 2010, 03:50
