An encoding standard designed as an extension of the MPEG-1 international standard for digital compression of audio and video signals. MPEG-1 was designed to code progressively scanned video at bit rates up to about 1.5 Mbit/s for applications such as CD-i. MPEG-2 is directed at broadcast formats at higher data rates; it provides increased support for efficiently coding interlaced video, supports a wide range of bit rates and provides for multichannel surround sound coding such as PCM, Dolby Digital, DTS and MPEG audio.
Results 1 to 1 of 1
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
