  1. hi all
    im having probs with tmpgenc plus the avi file gets about 20% through and then i get a privelage error and i dont know wot to do ive changed setting in environment scanned for errors with vdub mp3 /freeze and still nothing any info or help would be very much appreciated
    many thanks
    leatherface
  2. Banned
    Jun 2001
    UK
    Normally TMPGEnc will crash if it reaches a bad frame make sure you done the scan right.
    KingJohn's Guide to bad frames V2 VBR Update
    You may be able to use the source range and set TMPGEnc just passed the error at 20% to do the rest.
