I have a .m2v file and a .ac3 file. It is over 4.3 gigs. What I want to do is convert it to a smaller size so it can fit on a 4.3 dvd-r. In rempeg2 it was suggested in a guide that rempeg2 check every single frame of the movie before moving on. What I did in the program is clicked on open and then clicked on my .m2v file. It went through all 19 of my .m2v files before it got to my 20th .m2v file which it then said
" Unsupported resolution 4294967295 X 2012750850..."
then it said there was a error with the program and asked me if i wanted to send the error repport to microsoft. I said no and the program shut down. I tried again and this time the program did not shut down. The 20th .m2v file plays just fine. I dont understand. Do I have to do this step in order to make a dvd file smaller enough to fit on one dvdr or is this unnecessary step?Is there an easier way?
Results 1 to 1 of 1
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
