Made many attempts to fit 104 min DVD on a MP1 VCD. With MPGEng set to 850kbs Vid and 44.1 khz I can get below 700MB. But I get a warning from VCDEasy and the end of burn the VCD has problems. Any advice![]()
what are the errors actually saying? the only ones i got from vcd easy were about auto padding. i let it burn it turned out jus fine. plus, try gettin the new version of vcdeasy if u dont have it
The only error and it is more of a warning occurs prior to VCDeasy making an image file and burning that says "Auto padding required do you want to continue? the movie may be unwatchable". I continue and the movie is pertty much unwachable that is the last 25% anyway. I just figure out how to enable the wizard features in MPGEng that will change the movie size more accuratly through bitrate. I hope this will stop the warning in VCDEasy. Thanks for the get back.
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
Padding Audio to match Video Length with FFMPEG?
By boyer in forum Video ConversionReplies: 0Last Post: 31st May 2010, 10:13 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
Resize video by padding
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 19th Sep 2008, 09:17
