im looking for a bit rate calc that'll have stuff like the number of passes and jointaudio..? anyone know where i could find one w/ those in it?
thanks
jerets
Results 1 to 11 of 11
number of passes and whether your audio is stereo or stereo are irrelevant as far as calculating the bitrate to use. The only thing that matters for bitrate calculations are bitrates--audio + videoOriginally Posted by jerets
Try using FitCD. it's a good one--easy to use too, and it will even generate your avisynth script if you need to use one.what are you askin' me for...
I'm an idiot! -
Actually, the number of passes does matter, as single pass VBR will almost never be accurate.
yeah...but if you do a VBR encode at 2000k, your file size will be the same whether it took you 1 pass to do it or 10Originally Posted by furball6969
your filesize ends up being avg bitrate*length every timewhat are you askin' me for...
I'm an idiot! -
Almost, although you have to consider video bitrate and audio bitrate. And there is an overhead when the two are multiplexed, which varies between programs.Originally Posted by fantomlord
You can download FitCD here:
http://shh.dvdboard.de/
Hope That Helps!!!
:P
You could also try the Official VCDHelp Calculator also!
Here's the link to the VCDHelp Calculator:
http://www.vcdhelp.com/calc.htm
Hope That Helps!!! :P
I like the vcd help calculator. Simple to use. However, what do you use as the minimum bitrate? I'm sure it's the same for all since they don't include it, but what value should that be?
You can just leave the minimum bitrate at 0 unless your DVD player has a hard time playing low bitrate scenes. If it does, set the minimum bitrate to 500.Originally Posted by Rogue3
Hope That Helps!!!
:P
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Bitrate Calc Question
By cquetsch in forum Newbie / General discussionsReplies: 6Last Post: 24th Jun 2007, 19:11
