  1. i am using dvd2dvdr and i set the lower bitrate and in the end i still get 4.7gb ripped m2v file....
    W H Y ! ! ! !
  2. why don't you let the program do the calculation?? I have done more than 30 movies using it and never had a single probl
    [-Neoh*-]|[-Cheers-]
  3. Me too. I just let the program do it's thing.
  4. i have try but again....no help
    btw should i put cce in dvd2dvdr folder?
  5. wizzy
    If the movie you are encoding comes out too big just reserve some space in the encoder tab.
  6. Always reserved some spaces in the encoder tab. 50MB should avoid unpleasant suprise and not affect quality too much.
    You must install CCE 2.5 with the install program and you dont have to install in the DVD2DVDR folder.
    BTW DVD2DVDR produce 2 sets of M2V files. The original one and the new encode one. Make sure you select the right one...
  7. ok, i have problem with dvd2dvdr he could not find the cce in my pc he is looking for the installation ,
    i have installed standalone cce on my pc and it work fine as standalone,
    dont know why dvd3dvdr cant find it...
    Nov 2002
    Mechelen-Belgium-Europe
    W H Y ! ! ! !
    Maybe you are doing something wrong?
    Try to follow my guide @ http://users.pandora.be/DVD2DVD-R...
    -BK-
