I am in the process of ripping the Sopranos first season. After I ripped the first dvd, I had 7 gigs of info. I converted it over with DVD2avi. That made my audio file around 2.1 gigs. When I try to run it in MPGEnc.exe it says I have an error when audio is decoded. I think that maybe the audio source is too large. Is there an adjustment I can make in the ini.file or something so it will take the large audio file? What can I do to get through this problem?
Sorry for posting this question twice but I really wasn't for sure where it should go.
I suggest to decode in 2 parts. Use DVD2AVI's source range to look for a point, where you want to split the file anyway. So you get two .d2v and two .wav files.
Both TMPG audio encoder and toolame do not accept >2gig files. -
Your the man Truman!! I can't believe I over looked that. I am new to these programs and never had to do that before. I really appreciate your help. I have already wasted two nights with these large dvd's. Maybe I can get somewhere tonight. Thx again Truman
Tmpgenc Xpress 4 stream reading error
By WinSpecToR in forum Video ConversionReplies: 8Last Post: 16th Oct 2008, 07:50 -
H&B DX-3255 reading problems.
By brianstivala in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Mar 2008, 06:43 -
JVC DR MV-7 reading problems after hacking
By PTCAL in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Feb 2008, 03:47 -
Problems reading MPEG files off of HDD
By tedv in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Oct 2007, 10:20 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
