An encoding technology developed by Dolby Laboratories, Pro-Logic and Pro-Logic II are methods of encoding 4 channels for Pro-Logic (left, right, center, surround) and 5 channels for Pro-Logic II (left, right, center, left surround, right surround), into a stereo (left, right) channel format to be decoded into 4 or 5 channels with a proper decoder. It is actually just a small amount of inaudible data slipped into a stereo audio stream that can be reconized by a decoder so that the decoder can separate the stereo signal into 4 or 5 channels. A Pro-Logic signal can be encoded into any form of stereo audio stream including digital files such as mpeg-1/2 layer 2, MP3, uncompressed PCM, audio CD's, and it is also used to get multichannel in VHS tapes and other analog sources. You can listen to Pro-Logic encoded audio streams with any normal equitment but you will only have 2 channels. DVD players are required to have a capable Dolby Digital decoder to downmix a 5.1 Dolby Digital signal on DVDs to a Pro-Logic stereo signal to be output with analog RCA cables. Pro-Logic II can be decoded with Pro-Logic decoders but you will only get 4 channels instead of 5. Pro-Logic is also called Dolby Surround. Dolby
here you can find how put the sound files in your stereo file so the pro logic decode can reconaice them ok:
http://www.ctv.es/USERS/avi/dolby.htm
it is in spanish, you can translate it by google.
Dolby Pro Logic IIx encoder
By nateo200 in forum MacReplies: 4Last Post: 4th Feb 2012, 14:45 -
No Dolby Pro Logic from AC3Machine
By jonghyunchung in forum AudioReplies: 9Last Post: 28th Jan 2009, 15:35 -
Dolby Digital switching to Pro-Logic
By toneystone in forum AudioReplies: 4Last Post: 6th Jan 2009, 07:11 -
dvd audio and pro logic
By tommcd64 in forum AudioReplies: 1Last Post: 31st Oct 2008, 20:23 -
A Few Questions About Dolby Pro Logic
By seven_deuce offsuit in forum AudioReplies: 17Last Post: 29th Apr 2008, 16:08
