can anyone advise how i can find out what codec to use for a .avi file i have downloaded from kazaa
Instal a little program called GSpot from here:http://www.headbands.com/gspot/
Here´s a screenshot of the GSpot:http://galleries.vinyamar.com/ps/show.php?id=THLTCvRL6XnbDdjxFZl2043bW
or just do like this and it will work:
Uninstalled all DivX codecs and xvid codecs,(Nimo Pack etc.)
You can then install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then install all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that install Nimo Pack but uncheck all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow
Install Nimo from here:
http://www.divx-digest.com/software/nimo_pack.html
Now all should work fine!
By the way,AC3 comes with the Nimo Pack and I installed this with
Nimo Pack Build 8,not the new Build 9 -
Test your system, see what missing, the file name will tell you what to install...Originally Posted by joshuaindi169
KingJohns Guide to Codecs V2
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
How do i calculate the correct bitrate for Xvid codec?
By Ingolf in forum Newbie / General discussionsReplies: 4Last Post: 9th Jan 2009, 10:32 -
AVICodec tells me I have the correct codec but video won't play.
By lesbianvirgin in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2009, 02:38 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 16:09
