i ve backed up loads of dvds using the same method but when i tried phenix nights series 1. i get this error
temporal references in gop #3(zero-based) are out of sequence (0xc10b000a)
i dont know what this means and dont know how to fix it anyone any ideas?
i used dvd2dvdr to rip the m2v and ac3 files then used rempeg to resize the m2v
if that is the only error -- ignore it and keep going ...
though i suggest using tmpgenc instead of rempeg ...
if it causes you a problem .. cut out gop 3
I need help with open gop i think
By Rathgar in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2012, 16:29 -
Which GOP program?
By pboong in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 13:19 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40 -
SCR <> GOP error in Gui for DVD Author
By rain in forum Authoring (DVD)Replies: 6Last Post: 22nd May 2007, 12:51 -
Glossery - Error in Closed GOP definition
By SCDVD in forum FeedbackReplies: 0Last Post: 8th May 2007, 19:08
