i have a DVD rip ...I think it is divx/avi...how long should it take to make a vcd...i have 800 mhz with 328 ram...and what program is the best to use & the fastest...I have TMPGEnc
Tmpgenc is the easiest way to do it, but it will take long. There's a guide for it on the site. If you can play SVCDs and can get your hands on Cinema Craft Encoder I would use that for the video.
First use Virtual Dub to strip the audio (roughly 15-20 mins) then use CCE for the video (roughly 3hrs). Make sure to uncheck the audio or you might get errors in CCE.
After that I would load just the audio in Tmpgenc and encode it for SVCD (another 20mins).
Then multiplex with BBmpg (another 20mins). This way might sound long, but I find it to be the fastest and best for me when the source video is good, like a DVD rip.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
