  1. Can anybody help. It seems that more and more files I get are in XVID format and I am not sure how to convert to SVCD or DVD.
    I generally use Virtual Dub to Extract the wave file and then TMPGENC to convert to either SVCD or DVD, but TMPGENC does not like XVID so I end up converting the XVID to DIVX using Virtual Dub. I can not believe this is the best way to convert the file. I have loaded the XVID codec but still TMPGENC will not work.
    Apr 2002
    The State of Frustration
    What does TMPGEnc say when it does not encode you XviD?
    Hello.
  3. thanks for the reply.....
    it says..
    Write error occured at address 77F536F7 of module 'ntdll.dll' with 0000000
    Apr 2002
    Have you checked the AVI files for bad frames? Click here for guide.
    Hello.
  5. hi
    I've had the same problems with bad frames,followed the guide found the bad frames and tried to save a avi, but run out of h/drive space. |The file seems to be over 6gb. I'am I missing something or doing something wrong?
    hope you can help!
