  1. I have made an AVI and paly fine from the bigining but if I use the fasst forward then audio/vidio goes out of sync. I have tried this with codacs, 3, 4 and 5!!
    Please advise help.
  2. you checked the avi for bad frames?
  3. Originally Posted by El Torro
    Yes I did that using vertual dub....I even did a direct stream using virtual dub with audio interleaving every 10 ms...
    Please note I used DVDx 1.7 to make the AVI.
