  1. i used to use the bitrate calc to try to fit movies on one cd. it didnt work back then. if i use it now will it work? take for example:
    1 hr 30 min XVCD
    1 - 80 min cd
    977 CBR
    will this movie fit on one cd?
    thanks
    Visit my webpage at:
    http://leech.at/e-z-e
    Apr 2002
    The State of Frustration
    It says it will. If I were you, I would use a CD-RW to be on the safe side.
    Hello.
