I only use freeware so it would have to be done w/ that.
Is there a way to tell ho big the dts (or any other sound file) track is?
I am just wondering so I can know whether or not it is even worth my while to try to strip.
in decrypter - go to the streams and check just the audio track you want.
it'll show the file size at the bottom.
-d -
how do I go to the streams
I set it to IFO mode and I can see the stream processing but nowhere does it say the size of the file
please help. thanks
Extracting DTS-HD track with tsmuxer
By rantonio in forum Blu-ray RippingReplies: 3Last Post: 18th Mar 2011, 09:23 -
Why did my DTS track get converted to 2 ch. PCM ?????? Please HELP :(
By Spdngblt56 in forum AudioReplies: 2Last Post: 12th May 2010, 03:17 -
Mux a DTS track to a MPEG2 TS file
By DrJonesIsBack in forum DVB / IPTVReplies: 7Last Post: 25th Nov 2007, 17:17
