Hey, i have virtualdub and i was wondering how to convert the audio out of it, i've got the movie to work but the audio still dosen't want to work, and i've tried using the azid converter but it dosen't seem to work or i am doing something wrong, anyone have any suggestions? I am trying to convert Enemy at the gates movie. It uses the AC3 codec for sound.
Results 1 to 11 of 11
Snipe65[with a squiggle]
What format are trying to convert it to??..the Azid I have converts fine to .wav file....then i use toolame to convert that to a mpg2 file
I would like to be able to conver the audio (ac3 codec) from my avi file into the wav format.
This is my problem to ...have the same movie ...AC3 is driving me nuts .....i did a direct stream copy to wav in Vdub ...but the sound was soooo bad....tryed a million tools. Someone told me frame serv from Vdub...but how do i do that ...only get the video fron Vdub then
Try demultiplexing your audio.
This should be an AC3 type audio. You can use one of the freeware AC3 decoders to convert it to PCM WAV (e.g., AC3Dec). You can download this from doom9's site: http://www.doom9.net
Regards.
Michael Tam
w: Morsels of Evidence -
On DVD ac3 is coded in 48khz. Converting for (S)VCD? Make sure you downsample to 44.1Khz. You can extract and downsample using DVD2AVI.
DVD2AVI will also do a ac3 -> dolby surround audio mix. I don't know the order DVD2AVI handles things. Preferrably this should be:
1. surround mix in 48khz
2. downsample from 48 to 44.1khz
Can anybody confirm this is the order DVD2AVI will do this?
If not, I am looking for a separate tool to convert 48kHZ.wav to 44.1Khz.wav.
Anyone know?
Thanks, -
Yes, Dvd2Avi will mix and downsample. It will also normalize. Takes around an hour for the whole process on a 90 minute movie.
The problem with that is that the audio and video are encoded in a divx file and i can't seem to split them, converting the ac3 to wav wouldn't be hard but i need something to split the audio form the video with
I think i have had the same problem before, and I got an advice from someone to use GraphEdit, and that helped me. The program is kinda hard to understand I think, but I managed to rip the ac3 from an avi and save it as a wav, and it worked for me, you can try that prog..
// Robert -
GraphEdit works ...the sound is good and everything seems ok.....but when I multiplex it with the video....at the end the sync is terrible.....so ...is there a way to fix the syncploblem or did i do something wrong ?
AC3 to MP3 Conversion / Synchronisation
By sjdean in forum Video ConversionReplies: 5Last Post: 18th Jul 2010, 21:25 -
quicktime conversion and maintain 5.1 AC3 sound
By theendisnye in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 02:36 -
AC3 audio conversion
By exekutive in forum ffmpegX general discussionReplies: 9Last Post: 11th Nov 2007, 15:12 -
XVID AC3 TO MP3 Conversion problem help!
By sere83 in forum Video ConversionReplies: 4Last Post: 3rd Nov 2007, 15:55 -
AC3 mono to AC3 2 channel conversion help
By efiste2 in forum AudioReplies: 1Last Post: 21st Jul 2007, 14:06
